Good morning we use Bluebeam for structural steel take off on structural steel and architectural drawings
As you can imagine there are hundreds of steel section available and we have reasonably populated some and others are only as and when they come to light.
please see attached a document with deeper description however in essence the following is requested
- tool flyout button on right side of tool box to be bigger( wider) as its easy to mis and get the settings icon
2. that the popuout is adjustable and remembers the last size
3. each tool has an icon allocated to it so it can be identified as the tool tip takes too long to become visible
4. that the standard fields are available for all tool types eg label is not available for insert image, we use this for adding bolts, adhesive fixing, by plonking the image there and a adding a qty however the count field is also not available for image in the markup, other examples are in the base plate which are stanard items we would want to populate the width and height, this could be achieved with the area tool if we could have the image as an icon, i hope this is clear request, i would be more than happy to have a small teams meeting to clarify if required.
Kind Regards
John Browning
+64 (0)21 223 6001
John.browning@cullen.co.nz
