Hello Is it possible in Bluebeam to switch the angle measurement from degrees to per cent? In road construction, we need the latter more often. Thanks.
Set up a custom formula column with the expression "Height/Width*100" then drag an area measurement on any two points of the slope. The result will show %grade. Adjustments in the formula will need to be made for different vertical and horizontal scales.
