Hi All
Can anybody urgently help convert this pdf to dwg.
Apologies - new to Bluebeam!!
Thanks in advance
David J
Hello David,
After you open the PDF in Bluebeam Revu, Go to the Document Pulldown and select "OCR" then select the "ADD" tab to add the drawings you are working with and then within the options your can select the document type, and hit "OK"
This should allow your PDF to become an "Active" drawing, so you can take measurements, select text, etc. Here is a quick video that will give you more information: Run OCR
