I erased one digit of the original pdf. Then added one character in text box over the erased area. Color is black.
When I print, the character prints gray. And it looks gray in my "recents". (see "5" below)
Anyone have a clue why?
Not sure why @Geom, but do you have a "5" somewhere else on the drawing that you could capture a snip of and paste it into place rather than using a text box?
You could use the "erase content" option to clear out the character that you don't need.
Hope this helps. 😎
Great workaround David. Thanks
