This week, we're highlighting how to create the perfect circle in Bluebeam Revu!
➡️Here’s how:
- Navigate to Tools
- Click Markup
- Select the Ellipse tool
- Before placing the ellipse tool on your document → Press and hold Shift
…and now you have the perfect circle! 🔵
Resizing the circle is easy, too.
- Select the circle
- Press and hold Shift
- Click any control point of the ellipse and drag
Already made an ellipse and need to change it to a circle? No problem.
- Select the ellipse
Need to change the ellipse to a circle? No problem!
Revu makes it easy to create perfectly balanced circles by pressing and holding SHIFT with the ellipse tool.
👇️Share with us your thoughts on creating perfect shapes in Revu:
- Are you typically drawing circles for callouts, highlights, or measurements?
- How do you think using Shift-lock shapes could improve your workflow and reduce rework?
