When creating a text box, you can select a fill (always white in my case) as it may lay over text or linework and be difficult to read. When making a point to point measurement, I do not see the ability to put white fill behind the measurement calculation. For example, I'm measuring distance between two street lights to determine correct separation. My measurement in this case is 453 feet and the maximum is 350 feet. However, the box with the measurement amount is on top of line work which makes it difficult to read the measurement. Can a fill box for the measurement be created?
