Desired features:
You can do 5 and 6 already. As for the rest, I'll back you. Can I add too that if you format a field as a number, it automatically aligns right like Excel?
for 5, you would want to set your Subtotal to certain fields, and then your Total to the sum of the Subtotal fields. A pain yes, but it is doable.
for 6 you need some JavaScript. It is doable. You're going to want to talk to someone like @Liz Larsen or @Mitch Youngs for more information
Doug,
Thanks for the response. I know that all the items listed can be done manually; however, the effort is labor intensive. My goal is to have features developed that can accomplish the desired results without having to spend hours creating forms. For example, we have a bid form with 120 fields, formatting each individually is a tedious and repetitive effort that could be easily and quickly accomplished with the requested enhancements. Btw,
Mitch,
Thanks for your reply. We are hoping for tools that make creating forms more efficient.
I agree that Bluebeam could really do some things to make the form builder less tedious. Especially formatting multiple fields. Hopefully this gets some attention.
Items 1 & 2 are seriously needed. This software is too advanced in other ways to have to manually select 100+ form field and individually change the font.
