Hi,
I am using Revu Complete and one of the main reasons I got it is for Batch Slip Sheeting. However, I find this feature to be very inconsistent at best. 2 main issues:
- The biggest problem is that every time I use it, whatever sheet is replaced, it's book mark is broken. So if I import 50 sheets, then save, those fifty sheet's bookmarks no longer work. A bookmark audit will return 50 broken bookmarks. So then i have to go to each page and repoint the bookmark, or, delete all bookmark and then recreate them using the page labels. But that's not always a good solution because any bookmark properties, such as text color or text bolding, are lost.
So, I typically end up replacing pages one by one if there's not more that 20 to slip sheet.
I've engaged support with this issue, twice, but both times have been told that although they can reproduce the problem, a fix is not forthcoming because not enough people are reporting the same problem.
2. Even though the page labels match, either exactly, or the first character string, Batch Slip sheet does not find the matches. So I have to manually point the pages to their matches.
These 2 issues basically negate the use of Revu Complete for me. Anyone else having these same issues?
