It helps to change blend mode - use transparency, and color with overlay layers. It will be great if it is possible to manipulate the layers. I want one layer bright and other reduced opacity. This will help us work on many layers when you overlay.
@Chandanjk, I prefer using Snapshot instead of Overlay. It gives you full control to move, resize, and adjust everything as needed.
Here are a few extra details pulled from another post:
Thank you Shaya. That's a good solution.
