Suddenly, my space bar doesn't work with lower case text; just a continuous string of words.
Any suggestions?
That sounds frustrating @DennisT! Guessing, since you have spaces in your question, that this is just in Revu?
Usually when my Revu starts working in unexpected ways I restart the program. If that doesn't clear it up I close everything and reboot. 99% of the time that clears up the problem.
If that doesn't do the trick I'd reach out to Bluebeam Tech Support…
Hope this helps! 😎
I'm having the same issue on my Surface Pro 11 but not my Surface Studio. Did you find a solution?
