Prior to Bluebeam 21.7, I could press the <Control> key to have the program avoid snapping to objects. If I do that with version 21.7, it negates any drag-and-drop style of creating a polygon. If I have both <control> and <shift> pressed, it also leaves annoying line extensions toward wherever my mouse was when clicked, despite <shift> meaning the program is not supposed to draw to where the mouse is, but to a perpendicular projection.
Is there a workaround to avoid this? Will this be fixed in an upcoming version? Can I switch back to a prior version until that upcoming fix is released?
