I have Revu X64 Standard. The program just started closing if I use the shortcut key or the toolbar for either Highlite or Pen. Any files that are open are closed. Anyone seen this or have an idea why?
Haven't seen that here @knick. Running Revu 21.6 complete here.
I see your post is a few days old. Has this cleared up with a full shutdown/reboot of your computer?
No, Revu still shuts down with highlite and polyline. Strange. Just started for no reason.
Very odd indeed @knick.
If you haven't already I'd suggest contacting @Bluebeam Support Team through the Help menu in Revu. Hopefully they can provide a solution! 😎
The you, David, but I contacted support and was told Revu is no longer supported and they couldn't help.
Sounds as if you have an older version of Revu @knick. Kinda like our 2005 Jeep Cherokee, many of the current mechanics don't know how to fix it because they have only worked on newer vehicles…
You might consider upgrading to the current version. Hopefully the functionality that has been added since your previous license was purchased would make it worth it to upgrade.
Sorry I can't be of more help. 😎
Just got a laptop and upgraded. Too bad the new version is subscription only. The costs are becoming prohibitive. Nevertheless, there should be a clear and simple reason why my Revu 64 Standard just started closing when 2 shortcut keys are pressed. Planned obsolescense? Windows 11 upgrade? Operator error? Just curious but thank you for your attention. I can live with t.
