Hi all,
Looking for a bit of help here with Spaces.
I am copying spaces between services plans (Power plan to Lighting plan etc.) so identical building layout, but the space is often rotated by 90° regardless of page rotation. I have read the community posts on Rotating pages, but even if I copy the spaces (even grouped, similar to rotating markups by grouping with a rectangle) and rotate the page it is still 90° offset.
I am using sets, so copying between different documents. Scales are the same, page dimensions are the same.
I have attempted:
- Rotating the view both before and after pasting the spaces.
- Rotating the page both before and after pasting the spaces.
- Copy the space, paste onto the page it is needed, cut it to the clipboard, rotate the page and repasting the space.
- Combining both pages in the same document, and attempting all of the above again.
None of it works, the spaces are always +90°.
Is this a known issue, and has anyone found a way to fix it? I am working with hundreds of plans, so manually creating 40+ spaces for every plan gets frustrating really quick.
Sidenote to the devs - can we add rotating spaces as a feature?
Original Space:
Pasted Space:
