Like all windows, I can drag the Revu window by clicking the Menu bar and holding while moving the mouse. However, I can only do this when there is a "black area" to click. Any other spot has a drop-down tab, my account info, etc., and cannot be dragged from that spot. This isn't a problem when the window is wide enough to produce a black area. But if the window is shrunk down, which happens often, then the black area disappears.
The menu bar should be revised so a Revu window of any width can be conveniently dragged by the bar.
