I only want to use dynamic fill for markup, I don't need to measure. I can do the fill but it won't save without applying some sort of measurement (and even that doesn't work)
If I'm understanding correctly @RyanM you are looking to fill the area with color, but not display a label or measurement value. If this is the case, you can use dynamic fill to create a measurement and then adjust the properties of the measurement to turn off the caption so all that you have is the "markup color".
Once you have established your "no caption markup" you can use dynamic fill to apply that same markup again and again. 😎
Maybe I am not understanding the issue, but when I use Dynamic Fill to create site maps and logistics docs, I just use the Polygon icon under Dynamic Fill and don't select any of the measurement icons
