The stapler is one of my most used tools, but there are a few functionality features I would like to see added:
I nearly always use the Combine function to create multi-page documents @Isaac.Harned , what do you find are the main benefits of using the Stapler instead?
If you are talking about the right click in explorer and combine, it is still the stapler that does this. If you are talking about combine in revu, then I would rather be able to multi-select within explorer and combine in that way. Either way, neither option gives me the ability to create bookmarks based on folder structure or index, so adding that functionality to both would be great.
That makes sense - thanks for the update!
