Is it possible to create a feature similar to "Create Page Labels" that would use a selected region on a page so set the drawing scale for multiple pages in a drawing set? By selecting the scale window of the title block each page could be assigned with its correct scale even though they may be different.
@Karl Heckman (seeing you are an architect, and assuming you use Revit) Have you tried to export your PDFs from Revit using the Bluebeam plug-in? Those will carry over the scales of each view, even if a single sheet has multiple views with different scales (like details).
@Carina What if the BB Plug-in does not work, is there still a way to carry over the scale of views other than applying the scale manually?
