A coworker just asked how to go full-screen on a PDF, and I showed him the "full screen and Presentation options. One issue that came up was that the shortcut for Presentation (ctrl+Enter) didn't work. Any ideas why?
One possibility is that another program has the same keyboard shortcut and it's ahead of Revu in the pecking order.
Happened with me and <ctrl>+z
That makes sense. Not to figure out what program is doing that. 😊
