Am I able to transfer my account licensed for Revu 21 to a new PC? I'm retiring my old PC with a newer model but I want to know if there was anything special I needed to do to have my account license on the new PC. Windows if it makes a difference.
@Manuel A Santiago, From what I understand, you just need to download Revu 21 on your new PC and sign in with your BB ID. (If you're using Revu 20 or earlier, you'll need to enter the license code that was emailed to you.)
Hope this answers your question.
But FIRST, Sign Out. If you don't, Bluebeam may think you are using your license in 2 or more locations simultaneously. When this happens, it does not let you sign-in until you sign-out of the other location first.
Good advice @nexlevel801! In my experience however, I can log into my laptop without first logging out of my PC since it just kicks me off automatically. Same goes the other way. That said, better to be safe than sorry!
