Can you add the option to create an arrow or circle etc. at the end of an arc segment (without having to draw one manually using a polyline or lines) similar to how you can do this with polylines or lines
If you draw a polyline and convert it to arc, then you can have an arrow at the end of a curved line. There could be a simpler solution though, so still a good suggestion.
