We build a lot of forms and make them fillable. When doing so, or even when opening up a form with fillable spaces, you should be able to select the fillable boxes and adjust the properties individually, or in bulk for the entire form, as needed. This would be a great help when you have built a form, for example, and all of the boxes are on automatic sizing of text, and you would like for them all to be set at a size 12 Arial. This is used more often than most realize when working with forms.
