Currently coming across this issue whilst creating Tool Chests.
Our company has a variety of symbols, with each symbol having a tag / label associated with it for use on drawings. Some of these symbols are quite complex (e.g. Emergency Exit Running person).
The ideal outcome is to be able to have the following Group Hierarchy:
Tool / Group:
- Group A - Symbol
- Item B - Text box with Symbol tag / label.
Currently, this is not possible, as adding a single item to a pre-existing group merges the item into the group, which then is an issue, as there is no simple way of extracting the text box from the group without ungrouping the whole group.
Similarly, having 2 text boxes stacked on top of each other wouldn't work, as then you cannot adjust the text box size (i.e. if using a long label); instead it scales the text box (including font size).
Desired outcome:
To be able to add a single item to a group without it merging in to pre-existing group.
Acknowledge this is different from existing functionality, so hoping for a new shortcut and item in the context menu when grouping things together.
