how do I filter out only my mark-ups to transfer to another PDF as when I window in the whole document alot of other stuff is highlighted?….
I just want this stuff….
Assuming page numbers are the same in both PDFs, try
or
2. Markups List —> Filter by Author —> select MUs —> Copy —> Paste
It would be good to see your Markup List and what customisations you have made. The point is to consider the Markup List as a database and look at how you can manipulate the data. My apologies if you are not new to this concept 🙂. Jes's answer is perfect in answering your specific question, but what if there are other markups? Or only select a few of your Makups. One simple idea would be to create Custom Statuses with a "Transfer" and potentially a "No Transfer" option and then create a filter to show only the "Transfer" status markups. Then save this Filter in your Profile for future use.
In Jes's options above, I tested No. 1 and it will transfer ALL Markups - you could use the Filter for "No Transfer" to isolate all the Markups that you dont want and delete them. Jes' No. 2 option works. Oh have a look at Slip Sheet and or using Sets to update Markups automagicly from one drawing to another. 👍️
Good details to consider there @Shanoc Halliday . It reminds me of something else to potentially help with this operation… Sometimes it is necessary to SAVE AS the PDF in order to isolate markups that need to be transferred. If you filter markups then delete unwanted markups in a SAVED AS file, you can isolate the markups needed to work with rather than fighting with the markups list functionality limiting its own usefulness with the "clutter" of markups from other Authors.
Hi everyone! What is the experience with Revu on Mac via Parallels? I have been exclusively using in the past decade Revu on several iPads for marking off, measuring, take offs on the go but now as the iPad app gone and the new Cloud / Mobile replacement is still in the cooking I am forced to seek alternatives. As I have…
Can Bluebeam convert a .pptx file to a PDF, and if so, how?
How do I show a file path in a text box?
Hi, brand new user here. Just sat through several hours of tutorials, and I'm trying to determine how useful Bluebeam will be for tracking my daily as-builts on a road project. I'm one of the first inspectors using Bluebeam here. The problem I am having is using the Polyline Sketch-to-Scale. I cannot seem to edit a drawn…
知っている方が居たら教えていただきたいのですが、図面を翻訳する機能はありますでしょうか? よろしくお願いします。
I am trying to delete a previous session and entering a new one. I keep getting an internal server error. Does anyone know who to get a hold of to fix this?
i cannot see my properties panel. it only shows up if i change profiles. i cannot use shortcut key Alt-P to make it visible
When I am trying to search for keywords on a plan/document, it displays 0 results found. This is the first time I've had this problem. Does anyone know why that would be?
We are currently reviewing our licenses and find that we lack the necessary functionality to scale up or even maintain our current number of licenses. We would like to see functionality for creating and managing templates for control plans, commissioning protocols, checklists, and similar field documentation, with results…
I hope that is what the feature is called that I am referencing. I have used Blue Beam now for a couple years. I have always used the Line and Polyline tools when drawing things, especially overlays to buildings where I want to keep nice straight lines. In the past, I could select the tool, let's use Polyline: if I held…
