Did you know that you can tone down or dim the content layer of a PDF to make markups easier to see?
How?
Just go to the View menu » Dimmer » Dim Content. The effect can be seen in this example:
Set the level of dimming
- Select a percent from the Dimmer menu.
- The lower the percentage, the less intense the underlying PDF content will appear compared to the annotations.
Dimmer set to 100%
Dimmer set to 30%
⚡️ Bonus Tip: Press CTRL+F to toggle the dimmer on and off
👇️ Drop a comment below and tell us:
- When have you found dimming the content layer of a PDF beneficial?
- Or, if you didn't know about this feature, when would it have been beneficial for you?
