When I try to search a set I always get 0 results and the result is instant.
It doesn't appear to be actually searching the documents.
Am I doing something wrong?
You're searching for "d:P2N-1013", correct? You're certain that combination exists, correct? Is the search term a markup or part of the document? Is the document a scan or printed?
I haven't worked with sets before so maybe that's the limitation. Can you successfully search by Current Document or All Open Documents?
the text is searchable in the pdf if I open the file.
I’ve had this issue in any set I’ve created. It can be a large set and the search seems to complete instantly with zero results.
