I was trying to figure out how to change the text size 1 to size 0.5 and every time I use the font size text box to change the number to 0.50 it'll default the size to 8.
Is there a way to change the text size smaller then 1?
Hi @Tukrong! The current range of values is 1-144. The dropdown will provide some options 2-72; manually input for other numbers.
You are correct — unfortunately, a value less than one goes back to 8.
