Revu 20/21 arent able to zoom while drawing some markups with navigation setting "scrolling" enabled
Have you tried holding CTRL while spinning your mouse wheel to zoom?
I was about to suggest the same thing.
thank you for your reply. I normally zoom with CTRL+mouse wheel, but if i use some markups (experienced this only with sketch tool) Revu scrolls regardless if i press and hold CTRL or not
Ah… You may need to check preferences.
thanks, but I don't want to alter my settings. It's just a workaround, but if you want to zoom while drawing some markups, you have to press CTRL+SHIFT+ALT to be able to zoom and then press CTRL+SHIFT+ALT again to deactivate "ortho mode".
OK. Sounds like you made it work for you. Good show!
