I regularly receive large sets of drawings whose filenames are ridiculously long, which makes navigation using tabs nearly useless. While I can use the Sets panel, I often know which of several "key" sheets I'll need to refer back to on a regular basis, and it would make things easier if the document tabs were readable. If there was an option to allow listing the Sheet Number Set Property in tabs, instead of the full document file name, that would be very helpful.
