I have my scaling precision set to 1, however I noticed that in the legend the totals are not adding up correctly. It seems like Bluebeam is adding the actual "precise" measurements regardless of what is displayed, and the precision setting being set to 1, and then rounding up that new total (See attached screenshot, total should be 76 not 77). If I adjust one of the measurements slightly the total will then show correctly as 76 even though the measurement itself doesn't change. I shouldn't have to slightly adjust all my measurements just for the total to be correct based on what the markup table shows. Is there another precision setting that I may have missed?
