Are you referring to these columns?
This discussion has been moved from Product Ideas to the Talk Bluebeam topic to gain more comments and visibility. However, this feedback has been recorded for our Product Team.
I would guess it to remove the "Comment Column" when toolchest items are in Detail mode. The comment column takes up valuable realestate and unable to open the Subject column wide to view easily without opening the whole tool chest very wide. @Willem Kraaij This would be a great fix.
When you click on 'Manage Tool Chest', select one of the existing Tool Chests and click 'Modify'.
From here, you can edit the name for each tool chest. You can also select the red "X" to delete the tool chest that are no longer used.
As far as the columns continuing to narrow, I do not have an answer for that. I agree with @Brent that the comments column should be removed or at least moved to the right of Label.
When working in the detailed view of the Tool Chest, I find the "Comment" column takes up too much screen space. Is there a way to hide or rearrange it? I’d like the "Label" to be more prominent instead.
This request has come up a couple of times. The answer so far has been "no" but go vote on the top link so they can see how much interest there is in this option.
@Marco M time to merge posts?
Populous is hiring for a Computational Designer that sits on our Global Digital team. Link below to apply today! https://populous.com/careers?gnk=job&gni=8a78879e9c9ca640019cbacb46066ef9&gns=Recruiter
Hi!, I'm a senior technician in an architect office, and I regurlarly do some site surveillance and dificiency reports. I am looking for an app on a tablet to consult plans (pdf format ideally), annotate them with comments (ideally speak-to-text) that will generat a list of comments with a "pin" on the pdf plan localising…
If you choose an area and set the color, line weight and so on, then click out of measurement you have to then go back and redo all the particulars for that item that you are trying to take off. Can this be remedied? Onscreen allows the user to set a group of items to use repeatedly throughout a set of drawings (color,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad? The image below is how you see it on Bluebeam for Web: The…
How do I ensure my session allows for plan review markups? I cannot sort out how to enable one of my sessions to have both the review and plan review tab.
