When I try to overlay two documents, I have my default settings set to "all pages", however, I have to manually change each document in the overlay list to all pages. Why is this function not working? It used to work in older versions (2015).
Hi @hungpa
May I ask which version you are using now? If you are using Revu versions 2019 or older, we will not be able to assist here as these versions are no longer supported on our end.
If you are using versions 20 or 21, can you please use the contact form below to reach out to our Support team? We will reach out to you as soon as possible.
Many thanks,
Hercia
Hello all, I've been searching around trying to figure out if this was possible but have had no success. I'm wondering if it's possible to take 2 or more exhibits and combine them along the matchlines 'WITHOUT' snapshot. Snapshot essentially turns it into an image. My intent is to retain the attributes of the original .pdf…
this change from Bluebeam for iPad to Bluebeam cloud just made the program useless. When we are in the field, attaching a photo to a markup was 80% of the point, so when exporting a summary, the photo would be with the callout. How is this most-used feature gone? I am just now finding this out at 1am and have to travel in…
I have installed Bluebeam on a new laptop. Trying to read pdf files is not happening. Thumbnails show up but main window is either gibberish or blank. Have shutdown and then restarted and deinstalled and reinstalled to no effect. Repeated attempts to access Bluebeam result in laptop freezing and need to hard shutdown to…
Hi all, I have many tools showing as disabled & can't do my take offs. This includeds my tools in my tool chests. Any suggestions before I cry?
The rectangle function will allow a colored fill to be used, as will the ellipse function. Is there a way to "fill" an area that is defined by a polyline?
I've created a dynamic fill of an area on a PDF, and am unable to delete it; even using the Dynamic Fill option to "Clear All", "Clear Fill". How can I delete/erase this dynamic fill?
When I add digital signatures, the window doesn't close after I'm done. It doesn't freeze. I cannot change locations on the document. It will stay open and let me repeat the exact process but never closes. I have to go to Task Manager and close Revu. Any thoughts? Thanks,
I recently upgraded my bluebeam from Core to complete. now my interface is on view mode, i have tried to comeback to markup mode but can not fine the markup mode please i need assistance.
After the recent update, my search function does not work any more. I have tried my files including the ones I have successfully searched words in before the update. Is this a bug? How can it be fixed?
Just wondering what everyone is using in the field other than an IPad? Any Galaxy Tab, etc. users out there? If so, have you got any feedback?
