Edit/Unlock markups in Studio Sessions
Please add the ability to allow some users to edit/delete other peoples comments. This can be controlled through permissions.
At our organisation when reviewing drawings there is a review manager that consolidates comments before sending them back. This process occurs regardless of if we are using Bluebeam or another tool.
Our current workaround is to remove the documents from the Session, make the edits and then re-upload to the session. However this causes issues as all the comments are then locked (even from the users that made them). It also means those changes aren't tracked in the Session audit history so its not clear what was changed.
31
31 votes
Active · Last Updated
Comments
  • I'd like this simply because sometimes the mark up has a typo or references the wrong thing.
  • This has come up a lot over the years. I believe the restriction isn't a design or programming issue, but more of a legal one. If I'm a subcontractor invited into a session by a GC, with this setting, they could potentially change my comments. This would be possible to anyone invited into a session that is owned by someone else.
    Would require some trust on all parties. For internal use, I think the idea is fantastic.
    Ken Phelps
    Sr. Product Specialist, USCAD
  • Alan A.
    Alan A. Posts: 50
    Hi @Colby Gallagher - TfNSW - DE Manager,
    Thank you so much for reaching out to us about allowing users to edit other people's Markup in Studio Sessions, and we've taken note of your request. Could you share anymore detail about why your review manager would delete a comment or Markup?
    Please let us know if there’s anything else we can do or if you have any other questions. We look forward to potentially collaborating on future projects.
  • We have the same problem… our lead reviewer consolidates and verify comments from engineers. any conflicting comments or comments that is not needed must be remove. The lead reviewer finalized comments before document controller sends it to the originator. If the review lead cannot remover or delete comments that is not needed it is causing a bottle neck / delay. Please make this happen. The session report should capture any removal deletion of comments so there is a security in place.
  • There are a NUMBER of use cases where being able to edit other people's edits/markups would be tremendously useful. Others have spoken to the need for comment consolidation + cleanup, but I'll mention another key reason:
    We often use Bluebeam as a sketching tool - it's very powerful for this. If users were allowed to edit each other's drawings/sketches it would an INCREDIBLE tool for collaborative design during live sessions, concurrent editing sessions.
    I'd REALLY like to see at least an option on a file-by-file basis to allow for editing each other's markups. Thank you!
  • 100% agree with this request. There needs to more flexibility in session permissions. I can understand the legal rationale for the current defaults but it lacks flexibility and actually hinders collaboration for the use cases described in other posts. In particular, allowing a meeting facilitator to edit/consolidate comments from anyone on the team live during a meeting would be helpful. Also agree with allowing edits of each other's drawings/sketches to enhance the collaborative design process.
  • Another use case for this request: I would like to change the "Check/Unchecked" status of another user's comment. Currently, I need to right-click, "Set Status…Complete". Using the "Check" status would save clicks and time. Why are we able to change the "Status" but not the "Check"?
  • This would be helpful to my internal team, too. Our PDFs are essentially living documents with changes tracked in red ("redlines") over several weeks or months, after which those changes are incorporated back into the original source and a new updated PDF is published.
    Even if person A updates the equipment and PDF with change A, we often have person B come along with further necessary changes B, and occasionally even have person C with more necessary changes C. It is absolutely helpful to track that final change "C" is an amalgamation of changes from persons A, B, and C, but it is not helpful for latter persons to have to cover up previous updates with e.g. a blank white rectangle.
    And when using the "cover up" method, the final reviewer who is incorporating changes back into the original source is forced to wade through conflicting markup history from three different people on the same page. By supporting markup edits, the final reviewer would only have to review a single markup history collaboratively created by three people.
  • I have heard the request over and over to unlock the markups in Studio Session so not just the author can edit them. I understand the purpose of locking them to safeguard the integrity of the original intent of the author. If you could make this an option in the Session Settings, it would be nice if the Session Owner had the ability to choose lock or unlock. Sometimes we need both and the Admin should be able to pick.
  • Carina
    Carina Posts: 61
    edited September 2024
    Or at least allow the Admin the ability…..
  • Colby Gallagher - TfNSW - DE Manager
    100% agree. I have also raised this suggestion here - https://community.bluebeam.com/bluebeam-community/discussion/comment/1235#Comment_1235
  • Travis Shupe
    Travis Shupe Posts: 3
    Yes please!!! My entire firm would LOVE to have this ability. There are times were we use Studio Sessions internally, and it would be AMAZING to have the ability to edit each others markups. As Troy said, making this an option that the Session owner can enable or disable would be ideal. There are already permissions setup for Session members, so perhaps adding the ability to edit ALL markups could be added to these permissions.
  • stobin
    stobin Posts: 1
    Very much agreed. Being unable to edit other peoples' markups has been a huge pain point for our team. If we had the ability for the Session owner to allow it as an option, it would open up many more possibilities for Sessions.
  • Hi, I couldn't agree more with this request. I completely understand the legal issues with allowing others to edit markups, which is why the request is to make this a permissions setting. That way the owner is in full control and can allow or deny this ability to each individual at any time.
    I would take this a step further and say that by default the permission should be to NOT allow editing of other people's markups. It would require the owner of the session to specifically adjust the permissions settings on a user by user basis.
  • Marco M
    Marco M Posts: 182
    Merged related ideas/feedback to this post to reflect a more accurate vote count for our Product Team.
  • dmfrost
    dmfrost Posts: 1
    Afternoon Everyone,
    First, I would like to say that I am very encouraged that this is an open conversation with the Bluebeam Program Team instead of being dismissed due to a possible change in company direction. Bluebeam's willingness to improve and make their program cater to their users' demand is the reason why I love using Revu in the first place.
    I am writing to add a suggestion to possibly mediate between user demand and Bluebeam's valid concern for documentation legality. My suggestion would be for Bluebeam to create an "add-on" to Revu that would be dedicated to document collaboration. Create a new "studio" platform called - "Collaboration" (See illustration below)
    By creating a new studio platform Bluebeam can maintain the integrity of "Projects" & "Sessions" - just a suggestion would be to add a wet stamp or something on the document to capture. The addition of a "Collaboration" session would give Bluebeam an entirely new market to go after while also maintaining the platform of documentation integrity.
  • So, is there any resolution? I have the need to revise a change I made previously and it is also locked.
  • It would be incredibly helpful to permit cross-user editing of markups within a session. Like the OP, our architectural firm uses Sessions to internally review drawings. If markups need to leave our office, however, cleanup is necessary to ensure we are communicating clearly. Our workflow is similar in which the project lead saves a copy out of the session to do the tedious but important work of consolidating, formatting, clarifying of the multitude of markups to then send out. Keeping all of this within the session workflow would be ideal. It could even open up possibility for multiple "editors" involved in the cleanup process.
    Maybe there could be some sort of "suggest edits" feature in which one could manipulate a markup in a session that the other user would need to "approve" in order to take full effect (with tracking changes). Modeling after Google Docs may be worth considering.
  • I'm so glad this is being discussed, and hopefully considered by the Bluebeam development team. It would be incredibly value to have a feature where markup editing can be enabled for individual participants or for the whole group. This would be helpful for internal documents and reviews, and internal/external collaborative work sessions. There could be a popup when you sign into a session where this is enabled, and you would have to click to acknowledge that all comments are subject to editing. Or, like a previous person suggested, it could be an entirely different type of session for Collaboration (which has a whole world of other possibilities for new features). We would wind up using something like that daily in our office!
  • ericwg
    ericwg Posts: 2
    edited December 2024
    We use Bluebeam Studio Sessions to perform cross-discipline peer reviews of our A&E plans. Currently, the same permissions are applied to all the users participating in the review. Under that scheme, I don't have the permission to modify anyone else's mark-ups. All I can do is Reply to or Set the Status of a mark-up, which is typically what we do to disposition a mark-up. Having said that, it would be extremely beneficial if the person that setup the Session was able to create Groups which have permissions to modify the mark-ups of the other users within that Group. For us, the Groups would be established based off the discipline of the team members, i.e. Architects, Civil & Structural, Electrical, Mechanical & Plumbing, etc. Having his feature would allow the team members within the same discipline to modify each other's mark-ups. Having this capability would be valuable for many reasons.
  • ericwg
    ericwg Posts: 2
    I thought about this some more. While I would love to have the functionality added as described in my original comment, at the very least, or as a stop-gap, it would be helpful if there was a way to select mark-ups as editable or not. The default could be "editable by the owner only", but if there was an option to select "mark-up editable by all", that would be helpful.
  • gMAC
    gMAC Posts: 1
    It seems there have been zero updates or resolutions from Bluebeam regarding this long-standing user request for a necessary feature. Will there be any feedback or explanation from Bluebeam? Why has a viable solution to this critical issue not been implemented yet? Paying customers deserve a response on why we’re forced to navigate so many obstacles to use your product effectively.
    If this continues, I’ll advocate for my company to move away from Bluebeam and seek an alternative that better accommodates its users. We’re experiencing the same issue described by others in this thread (dating back to August 2024).
    Our team works collaboratively on drawings, compiling comments and markups from a large group across different states and countries. Since Bluebeam files can’t be collaborated on via OneDrive/SharePoint, we’ve turned to Studio. However, after uploading a document with hundreds of comments and markups (created and compiled by me), I found that even as the host of the session, I cannot modify my own comments or markups. This limitation is frustrating and hinders our workflow.
    We need the ability to edit comments and markups within Studio sessions. As many have suggested, a simple solution could be adding a permission setting that the host can enable, with a clear disclaimer if necessary. Any improvement in this area would help. Please take action—your users need this functionality.
