Hi,
When i first joined there was no option to select the UK as a country please can my profile be amended
Hi @Raymond Bell ! We've updated your profile for you! It's tricky because United Kingdom was down towards the bottom. Unfortunately, the profile fields don't auto-populate based on your location, so you have to type it in to find it. But you should be all set. If it happens again, just let me know. Thanks for joining and we're happy to have you here!
Also, I'll be moving this discussion to the Community Chatter category since this is a question that may occur for other members!
The last couple of weeks I have had a problem. When I click on a Session it starts to load it and then kicks me out of the Session and gives me this exact same message: After I select OK I can re-enter the Session I was trying to review without an issue. This happens every time I enter a Session that I was not in recently…
Since upgrading to 21.6.1, it seems I have to rearrange order of the tabs on each BB OPEN. I commonly start with about half a dozen tabs open for a couple of most active projects. I like to have them in order of Project 1 Specs, Project 1 CA Set, Project 1 Revisions, Project 2 Specs, Project 2 CA Set, Project 2 Revisions.…
When selecting text in Bluebeam Revu the cursor often behaves erratically and jumps around the page, highlighting areas that I don't want highlighted. How can I precisely select only the text I want to highlight?
Has anyone else ran into the error when trying to install/ update Bluebeam 21" Package Bluebeam Revu x64 Error: Error 1714. The older version of Bluebeam Revu x64 21 cannot be removed. Contact your technical support group." I've tried the following without any success: Bluebeam Clean Up Utility, various Registry and…
I'm trying to load a document with fillable form fields into a Bluebeam Studio session so that when attendees join the session, they can complete their portions of the form. However, when I add the document to the Studio session, all the form fields lock and cannot be filled. How can I make the fields fillable?
Our company currently has a multi-step process for hyperlinking our production unit drawings to our shop drawing details and then unit drawings to our part drawings. Firstly, we open the unit drawings and detail sheets, set up batch link, which requires a linking option setup with "open files" and link settings to be whole…
Is there a way to justify a large text block? I only see the option to align left, center, or right, no full justify.
After my laptop was replaced and I reinstalled all engineering apps, including Bluebeam. However, the Projectwise plug in is completely missing. Of course, not having plug in, I can't configure my datasources. All I have is sharepoint as document management system in preferences which is totally useless for me as for many…
Does anyone know how to add a user? I added a seat to our program but im not sure how to actually use it so someone else can use our program as well. How does adding the second user work?
log in I am really tired of having to log into Bluebeam every time I open it. Please figure out another way. This is the only application on our PCs that require this.
