is there a way to create page labels for a drawing set (ie 60-100+ pages), and then also add page numbering for sequential order (ie # prefix in front of custom page label)? it seems you can do one or the other, but not both?
@Shelby, you can do it in Headers and Footers with "Bates Number".
Just use the following settings:Number of Digits: 3 Start number: 1
@Shelby Here's how I handle it: First, add the page numbers using the "Header and Footer" tool. Once that's done, use the "Create Page Labels" feature with the "Page Region" option. Include the page number field from the header/footer when setting up the labels. There may be another way to handle it, and Id love to hear!
looking for way to add prefix, such as 001, 002, 003 within page label (sequentially, starting at any number), so not sure header/footer option will work for that numbering format
Recently, I've been experiencing and issue in that when I use my hotkeys for the typewriter or text box, they don't work. I used to be able to then go click the icon on the bar and I'd then be able to drop a textbox or get the typewriter cursor to appear, but now that doesn't work either. I just tried uninstalling and…
I am not able to choose different colors for my layers when I am overlaying more than 8 layers together. All I am seeing is the graded color palatte in revu v21 rather than the default one where we can customize the colors based on the RGB values. Has anyone faced this issue before? Is there any workaround for this to…
How do I ensure my session allows for plan review markups? I cannot sort out how to enable one of my sessions to have both the review and plan review tab.
Small Biz and we have BB Revu 20 still in our conference rooms because it does not require sign-in. I tried putting Revu 21 in one conference room and had it signed in with it's own account, but then there were server side issues and then login was required again. Users were confused and entered their own login for…
Some of the BB marked up PDFs I receive have shading and "draw order" out of whack to the point that I cannot read what's below the block. All of the items should come in like the "12' APPLES" unit, in orange. Any thoughts? The preferred "Order" would be with the shading at the base level and the pasted fixture block above.
we have installed the software and tried to login with "name_example.com" Account using "Bluebeam Australia Region"., But it is not allowing to login. Showing the error like below snip. But., we tried to login with "Bluebeam United States Region" and it allowed login, but the Plan is showing as "unassigned" like below…
Hello!! I have been using Bluebeam for a decent while, and anything I have trouble with I can usually sort out on my own, but I am stumped. We have a set of plans, all of which are images with a peach-coloured background. To save on ink, I need to change them to grayscale, ideally. Please see the attached screenshot. It…
On Windows, some PDF previews appear in my folders sidebar while others do not. It seems like the ones I created show a preview, but the externally generated ones don't. Is there a setting I can change to make all PDFs show a preview?
Has anyone had issues logging into Studio after upgrading to 21.9? I have a team member who can't get logged into Studio but can use everything else. Only thing he's done differently is upgrade. Thanks!
Is there anyway to customize keyboard short cuts for say the highlighter function? I would like to be able to have these for different colors.
