Do you know of an integration between Bluebeam and Procore that allows Bluebeam to mark up plans and sync to Procore? Thank you
Vinnie Seattle WA
@Vincent ProCore does indeed make an integration with Bluebeam. As of today, it lists as "Coming ****" on our Integrations Site, but that is just because they are just completing their upgrade from our old API endpoints to our new, easier to use API endpoints.
If you check out the ProCore website, it shows that their Bluebeam integration is available, but in Beta (because of the switch to our new endpoints).
Anyhow…. long story short: There is an integration that lets you push your drawings/documents from Procore into Bluebeam Studio for markups and communication and then it round trips your documents back into ProCore when you're done. All you need to do is reach out to ProCore to get the details!
Thank you Nate,
I will let the client know.
Is there a way to batch hyperlink a range of pages instead of the entire document? I have a 325 page document. Within that document are sets. There is an overall page with area references to that set. That set is page 58-78. I know I could pull the set out and do it, then reinsert. Just wondering if there was an easier way.
