I have added the checkbox from the 'FORMS' into my stamp, but when I add the stamp into the pdf, I can't check the boxes.
There is an article about creating interactive stamps. It's not too complicated once you get the hang of it, but getting started can be a bit slow. For my part, I used one of the predefined interactive stamps to adjust the design and fields to my needs instead of creating a completely new stamp from scratch.
If something didn't go as I envisioned, AI was able to help me fix the code.
https://support.bluebeam.com/revu/how-to/add-and-edit-interactive-stamps.html
We use the same arrangement for a submittal review stamp. Perhaps the same workflow applies.
Since the stamp tool applies a captured image, we have to edit the stamp for each application, changing the date, submittal (spec) section number, and edit the check boxes according to our status applied to the review, like APPROVED, APPROVED AS NOTED, REJECTED, etc.
This ensures the stamp is not editable and captures the record of our review before flattening.
So, summing up, rather than editing your stamp after placing/applying it in your PDF, edit AND SAVE the stamp before applying it.
Hi,
Were you able to add additional fields to the stamp? I'm currently working on customizing the engineering review stamp from the custom libraries, but I'm having trouble figuring out how to edit it without disabling the pop-up feature that appears when placing the stamp.
Ideally, I want the pop-up to remain active so that the reviewer can fill out the required fields immediately—without needing to edit or save the stamp beforehand.
Any guidance or suggestions would be greatly appreciated!
I am looking for the same idea.
Recently, when drawing lines, polylines, the linework on screen is extremely thick. Does not match the default line thickness, just really thick, rasterized lines. Then when the command/lines is finished, the line changes down to the correct line width. Is there a setting to fix this glitch?
Hello all, I've been searching around trying to figure out if this was possible but have had no success. I'm wondering if it's possible to take 2 or more exhibits and combine them along the matchlines 'WITHOUT' snapshot. Snapshot essentially turns it into an image. My intent is to retain the attributes of the original .pdf…
I have installed Bluebeam on a new laptop. Trying to read pdf files is not happening. Thumbnails show up but main window is either gibberish or blank. Have shutdown and then restarted and deinstalled and reinstalled to no effect. Repeated attempts to access Bluebeam result in laptop freezing and need to hard shutdown to…
Hi all, I have many tools showing as disabled & can't do my take offs. This includeds my tools in my tool chests. Any suggestions before I cry?
I've created a dynamic fill of an area on a PDF, and am unable to delete it; even using the Dynamic Fill option to "Clear All", "Clear Fill". How can I delete/erase this dynamic fill?
When I add digital signatures, the window doesn't close after I'm done. It doesn't freeze. I cannot change locations on the document. It will stay open and let me repeat the exact process but never closes. I have to go to Task Manager and close Revu. Any thoughts? Thanks,
I recently upgraded my bluebeam from Core to complete. now my interface is on view mode, i have tried to comeback to markup mode but can not fine the markup mode please i need assistance.
After the recent update, my search function does not work any more. I have tried my files including the ones I have successfully searched words in before the update. Is this a bug? How can it be fixed?
