What happens if you insert mailto:email@example.com as the link?
yeah thats wild. that legit just worked the way i intended. tech support just told me that bluebeam straight up didnt have that function. i appreciate it
Hi, We are new to BB and just starting to setup our templates, library etc. I have seen comments on using BB for punchlists and viewed on youtube but does BB have a learning page on how to set these up properly? We do large multi storey hotel projects and ideally want a live punchlist of sorts. Thanks for your help
I have the Revu Complete plan. Revu is largest user of memory on my system. Right now I have 4 plans open and my memory usage is at 2,486.6 MB I seem to hover around 2,000 MB. Could there be a setting I need to change which will reduce this usage? I have some lagging in other programs. I had attemped to use Studio once to…
Has anyone experienced this issue after updating to version 21.6? It doesn’t happen every time, but occasionally I get a popup that prevents Bluebeam from opening. When this occurs, I’m unable to launch the application at all. Just wondering if anyone else has run into this and found a solution.
Is there some reason why OCR works on some text in a drawing file and not other text? It looks to be the same font as other text on the drawing that OCR was successful in making searchable. Sorry I am unable to include a snip due to IP. Can anyone share their OCR settings? I've been using Bluebeam for years and still have…
Hello y'all ! Is there someon who know how to export coordinate of each control point? (Polyline, not polylength measurement) Thank you ! :-D
