Often when I'm typing in the "body" of my post and quickly hit the backspace, the body field disappears. Any idea why? And is there a way to bring it back without losing the content? If I "save draft" the body of the draft is empty.
HI @Luke Shiras - strange! I reached out to our vendor to see if they have any insight as to why this is happening. I'll keep you posted whenever I hear back.
I wanted to follow up on this as it is still occurring.
I thought it might be my Grammarly plugin or our Harmony Web Protection causing issues but this is the only place it happens and turning off Grammarly didn't help. It usually happens early on in my typing and is safe after I've been typing for a while.
It seems that after the "Save Draft" and "Post Comment" flash grey (Saving Draft…) the problem goes away.
I haven't experienced this here, but most of the time when things like this happen, reverting the changes should help. On Windows machines the shortcut to revert any changes is Control+Z, on Mac it's Command+Z.
Hi, We are new to BB and just starting to setup our templates, library etc. I have seen comments on using BB for punchlists and viewed on youtube but does BB have a learning page on how to set these up properly? We do large multi storey hotel projects and ideally want a live punchlist of sorts. Thanks for your help
I have the Revu Complete plan. Revu is largest user of memory on my system. Right now I have 4 plans open and my memory usage is at 2,486.6 MB I seem to hover around 2,000 MB. Could there be a setting I need to change which will reduce this usage? I have some lagging in other programs. I had attemped to use Studio once to…
Has anyone experienced this issue after updating to version 21.6? It doesn’t happen every time, but occasionally I get a popup that prevents Bluebeam from opening. When this occurs, I’m unable to launch the application at all. Just wondering if anyone else has run into this and found a solution.
I frequently copy excerpts from a PDF using the 'Snapshot' tool ('G' keyboard shortcut) and paste them into emails and chat (MS Outlook & Teams). I love that it can retain vector data and have customized resolution. However, I ran into an issue trying to copy the full page. Even with a basic, unlocked, 8.5x11 page with…
Is there some reason why OCR works on some text in a drawing file and not other text? It looks to be the same font as other text on the drawing that OCR was successful in making searchable. Sorry I am unable to include a snip due to IP. Can anyone share their OCR settings? I've been using Bluebeam for years and still have…
