Is there a way to insert a single page pdf into multiple pdfs?
I need to update the title sheet of multiple pdf's. I insert the standard PDF then update a few of the text as needed.
While there isn't a Batch Insert function, I was able to come up with a workaround that may help. Feel free to give feedback or different recommendations if anyone has them!
What I did was use the Batch Slipsheet function.
Unfortunately, when I got to the Match Function, it wouldn't allow me to match one sheet to multiple locations. So I made duplicates of that sheet and then used the function and that worked out.
I chose Manual Correlation before Match Pages.
And manually attached each copy to the first page of each multi-page document I was replacing the title page on.
This did work, and I imagine would still save you time. But, you will still have to take the time to make the copies of the sheet you're looking to insert.
Keep in mind that Slipsheet may not be an available feature in your version of Bluebeam.
Currently, the final output consists of only the intersection of matched pages between specified current and revised files. Please let me know if it's possible to include pages that did not match from the specified revised file in the output PDF.
When I go to Tools → Stamp and select a stamp, it displays the full file name in the dropdown, regardless of the title I set under the Properties of the stamp. This is a bit inconvenient, as I would prefer to see the stamp's title. The dropdown under File → New PDF from Template shows the title from the properties, which…
Can our .BTX tools be used in the Bluebeam Cloud for iOS? If yes, please let me know how. If not, will I be able to before the iPad app is deprecated at year end? Thanks, Dustin
For some reason my search tool doesn't work on certain pdfs and dont know why this is. Is there a easy fix for this?
I was wondering if anyone knows how to create a digitally signed signature (instead of using conventional digital signature offered)? I'd like to create a permanent image of my own signature on paper, store it and certify it if possible. Any suggestions are appreciated.
Can't find the split tool for polylines in bluebeam 2021. Youtube tutorials show the option, but it's missing for me. Don't want to redo all my markups. Help!
Working on a form and added the "reset form" button and it works as always. I'm trying to add a "print form" button but the issue I'm having is that when I click my print form button it will work once, but if you press it again, it won't work thereafter. I submitted this on ChatGPT and it had several options, but none of…
I got an email this afternoon asking if I wanted to sign up for this. "Interested in trying new Bluebeam innovations before they’re released to the public? You’re in luck!" It sounded interesting. I clicked the link, but the USA BBID doesn't take you to a login page. Is anyone else having this issue?
how to i change the line density when using the measuring tool? when i pull a measurement i click and the measurement stays as a thin blue line and not a thicker line
I am working on creating a custom toolset for my team to quickly calculate concrete and steel reinforcement quantities for bridge components. In order to do this, I have added quite a few custom "columns" which take inputs or store tool-specific variables. These are displayed in the measurement properties tab under…
