I have uploaded a batch PDF; I have noticed there are already layers that the Bluebeam software has picked up and added in the layer section. Please let me know if there is a quick and seamless way to perform these actions.
Clarification: The Bluebeam layers that appear in the Layers section do not appear in the markups section. Why is that?
Action 1: The action I am trying to preform is to measure all the double dashed lines on a page. I noticed that one of the layers that the Bluebeam software automatically picked up on is all of those doubled dashed lines that I need to measure. Currently, I isolate that layer and then use the measuring tool to measure all of those lines. What I am looking for is a shortcut. I would like to isolate those lines and then with one or two clicks tell BB to measure that particular layer. Is this possible?
Action number two: On another page in the same document, the Bluebeam software picked up the layers of single dashed lines and double dashed lines automatically but combined them. Is there a way to split a preexisting layer and then preform the same action in action 1 of measure those lines separately and in a seamless fashion.
Thank you in advance and look forward to your response.
@j_mcmanus23
Moved your comment into a separate discussion.
For the first part of the question, the layers you're seeing in the PDF probably came from the authoring software (Autocad, Revit, etc..). The reason why they're not in the markups list is the markups themselves are not assigned to a layer.
For the rest of the post, the answer unfortunately is simply, not an option today.
Now that the option to switch from Markup mode to View mode has been removed from Revu 21, is there a way to lock markups and comments so that you don't accidentally move or shift them while panning around in the file?
How would you remove hyperlinks in a document on a mass scale? Not going to each one and changing it's action, but listing all hyperlinks in one location and removing all in one fell swoop. I've looked thru the markup list to see if there was a way to display a list of all the hyperlinks in the document, but it doesn't…
Hello - When clicking on an established session I have been in before I get the spinning wheel then popup "Your connection to studio has been lost". After clicking OK closing window, it does open the session except it has "disconnected" me. Also does not show that in the Record that I have ever opened the session and any…
Is there any way to change the default from feet and inches to decimal feet? IT is a pain to change it every time I need a dimension. It did not used to be locked into feet and inches.
So , my question is that i'm noticing that the tools in the toolchest will automaticly rearange themselves in a surtain order. I believe only a few updates back this was not the case or a lot less. I could be mistaken as i,m still a relatively new user. Is it not possible to keep your tool in a surtain order and they dont…
I just updated to Revu version 21.7 and the tool that I used to snap dimesnions in length is now very wonky to use. It pulls fom the corner and not the centerline. Is there any way to revert it back to the previous version without abandoning 21.7 altogether?
Is there a Tool set for Audio-Visual? I use Revu for marking up drawing sets for the addition of A/V. I need to add things like data drops, electrical outlets, speakers, microphones, wall mounted monitors, etc. Does something like this exist in Revu? I have looked and cannot find a Audio-Visual specific tools.
Hoping someone can help me, or at least tell me I'm not crazy. I'm creating a stamp that when applied to the target document, will include a list of names that were entered in a dialog box, and then overlay a digital signature field on top of each name. Everything works except that I can't get the size of the stamp to…
Hi everyone, Just updated to the latest version and the "resume sequence" function is not working anymore. Anyone experiencing the same? Is there a way around this issue? Have the old version on another computer, the function works fine there on the same document
All of my office apps take forever to load the BluebeamOfficeAddin. Is anybody else experiencing this?
