Can you add a count to poly length measurements? For example, if I need a pipe strap and two concrete anchors for every 3 ft of conduit, can you add that to the poly length measurement?
Victor yes and no to your question. You can't add a count to a polylength. However, what I do is add a custom column labeled "# of Straps/Anchors", make sure it is a formula column and then it will take the overall measurement and divide it by 3 to give you a quantity of straps needed.
Thank you, that works. 🙂
