Eric, have you confirmed that your email program box is checked in the Bluebeam Administrator?
To get there go here:
2. Administrator
Mark,
good morning. thank you for your reply, time and efforts on this however, there isn't an email program parameter that is within our bluebeam administrator app. We are using bluebeam ver. 21.3.0.4216. the only tabs within the administrator are Plugins, Net Config, Printer and AutoCAD Page Sizes. The default email configuration is within Windows 11 Default App settings, unless I am missing something….(which could be the case.) Thanks again for your help.
Yes, that is a problem. You should see Office and Outlook on that list.
Try this…
