I am a civil QS and have been using Bluebeam for only 2 weeks. I'm struggling to measure curved corners in Bluebeam. In a drawing with several curved corners, I used the curved method in Bluebeam, but it's very time-consuming. Would it be possible to find a shortcut key for this, similar to Planswift where you can simply press the letter "a" and then manually click the center point and end point of the arc to measure the curved section accurately? In Bluebeam, I have to do the same and then make adjustments, which sometimes aren't accurate.
