As per attached photo - I've carried out a couple of measures but there doesn't seem to be the subject grouping like previous versions. Attached photo for reference. Any advice would be great on putting this back on the screen.
Not sure what is happening in your file in the image. But the grouping (sorting) is still a thing. Right now you are sorting by subject as indicated by the little blue line under the subject column header. If you click any other column name you'll see that blue line shift to be under that column name. If you click it again it goes from ascending to descending order.
