I have some reports that are PDFs and have to fill out regularly. I've been using the Forms to create text boxes and check marks that I can easily fly through. The problem I've been having is that there are multi-line fields that I fill out that I created multiple text boxes for. I recently discovered the Multi Line on the Options tab, and thought it would be a life saver, but when I do this the text is right below and doesn't align with the spacing of the form. It would be great if Bluebeam Form Text Box would allow me to select the line spacing of the text in a multi-line box in order to make it line up on the predetermined lines on my PDF document.
