Context:
Typically, a user is managing several sheets, several documents, different programs simultaneously. Capturing information from drawings, webpages, other pdfs is absolutely necessary in the industry. OR you have a reference project and you often reuse markups OR a user needs to create additional sheets with information on it / at least have it side-by-side with the main document.
Problems:
- Copying a sheet from Document 1 to Document 2. I don't think Bluebeam recognizes the Control (Ctrl) button when initially pressed. Only when it's understands that the user is attempting to implement Ctrl+C. So the issue is, it never copies the first time, and usually takes a 3rd/4th try.
- If you copy a text from Document 1, go into Document 2 but you have something already highlighted, Ctrl+V will paste not what you copied but what you have already selected/highlighted in Document 2, doesn't matter what page it's on.
- If you copy highlighted text that is bold, blue, and size 16... go into Document 2 and paste, it will paste the text in its default settings: standard text, green, size 10.
- If you copy a square from Sheet 1, go to Sheet 2 but you have something highlighted on Sheet 2 already, it will paste a Circle you created 2 hours earlier -not the square.
- If you use snapshot and copy the region, paste onto the same sheet, a different sheet, or a different document... it won't paste the snapshot but what you have had previously highlighted. Once an individual command is completed, most often, I'm not needing whatever is selected to stay selected/highlighted.
Solution:
Bluebeam needs to update its override rules. Something copied with intention to paste needs to override something that is highlighted. And when something is highlighted for longer than 30 seconds, it should be unhighlighted.
