๐ ๐๐๐ผ๐ฝ๐ฝ๐ฒ๐ฑ ๐๐ฒ๐ฎ๐ฟ๐ฐ๐ต๐ถ๐ป๐ด ๐๐ฐ๐ฎ๐ป๐ป๐ฒ๐ฑ ๐ฑ๐ฟ๐ฎ๐๐ถ๐ป๐ด๐ ๐ฝ๐ฎ๐ด๐ฒ ๐ฏ๐ ๐ฝ๐ฎ๐ด๐ฒ.
Consider a listed building survey somewhere in a European city centre, where half the record set is a scanned archive handed over by the local conservation authority, decades old, never born digital. A scanned PDF is a picture of a page, not text, which is exactly why Revu's search box comes up empty no matter how precisely you spell the room name on the sheet in front of you.
๐ข๐๐ฅ, run from Document > OCR in Revu, reads the text on the page, raster or vector, and turns it into data the document can actually search. Bluebeam's own guidance is to run AutoMark straight after OCR so each sheet picks up a page label, then use Batch Link to turn specified text across the whole set into working hyperlinks. OCR itself is available on every Bluebeam plan in Revu 21, while Batch Link needs Complete or Max, eXtreme on Revu 20.
What I would not assume either way, because Bluebeam has not documented it: how OCR performs against a poor-quality historic scan, or which languages it handles well, which matters the moment a European archive set is not in English. Worth testing on a page or two before committing the whole set.
Run in that order, a stack of scanned heritage drawings stops being something you page through by eye and becomes something you can actually query.
