Our company is using digital signatures more frequently for engineering drawings, and there are a few improvements that would make setting up signature fields much more efficient.
We are a multidisciplinary engineering firm, so a typical PDF set may have multiple people signing different sheets throughout the document. I like using Batch Seal & Sign and having each user sign the fields corresponding to their initials, but setting up those fields is currently very manual.
1. Add signature fields across multiple pages
It would be helpful to place an empty signature field on one page and automatically add the same field in the same location throughout a selected range of pages.
Currently, copying a field and using Paste in Place works, but it becomes very time-consuming on drawing sets that are hundreds of pages long.
2. Automatically rename signature fields
There should be an easier way to name signature fields based on information contained within the drawing.
For example, similar to creating bookmarks using a Page Region, I could select the user's initials and drawing number and use those values to automatically generate the field name. This would make Batch Signing much easier because the fields could be consistently named and easily identified.
Currently, I have to manually name each field.
Additionally, when renaming a field in the Forms panel, the list jumps back to the top after each change. When dealing with hundreds of fields, having to scroll back down after every edit is extremely frustrating.
3. Make signature fields easier to edit
Once a signature field has been placed, modifying its size or location requires selecting it through the Forms panel. Clicking the signature field directly on the document initiates the signing process instead.
It would be helpful to have a modifier key (Ctrl, Shift, Alt, etc.) that allows the user to select a signature field directly on the page for editing rather than signing it.
