Hi all,
I'm getting consistent stuttering and lag in Revu, even with just a single PDF open and nothing else running. These are normal architectural/construction plan PDFs (single large-format page, e.g. A0) that open and edit completely smoothly in PDF-XChange Editor on the same machine — so it doesn't seem to be a file problem.
System:
- HP Pavilion x360 15-dq1004ng (laptop)
- Intel Core i5-10210U, 1.6 GHz
- 16 GB RAM
- AMD Radeon 535 (2 GB dedicated) + Intel UHD Graphics (integrated)
- Windows 10/11 64-bit, GPU drivers confirmed up to date via HP Support Assistant
What I've already tried:
- Assigned Revu32.exe to the dedicated Radeon 535 GPU via Windows Graphics settings ("High performance")
- Checked/toggled Revu's 2D Rendering engine (Preferences > Advanced > 2D Rendering, Hardware vs. Software)
- Updated .NET Framework / Visual C++ Redistributable
- No noticeable improvement from any of the above
Question for the community:
Since PDF-XChange handles the exact same files without issue, what could cause Revu specifically to stutter on this hardware? Is there a known performance setting or rendering quirk in Revu that PDF-XChange doesn't have? Any tips appreciated.
Thanks!
