I have drawn a rectangle on to a pdf using the BB rectangle tool located in the bar that runs across the top of my document. I filled in the hatch w 20% dots however the dots are a color (red) I do not want to use. I see the fill color command in properties but that is not changing the color of the dots. Fill color simply fills the retangle w a color. I want to use the dots. How do I make this happen?
I do not see a tool to change the color of the dots.
